T
TRENTEND
Bought a traditional style close coupled toilet (£89 Cooke & Lewis Bainbridge) from B&Q -got out the box ready to fit and noticed some of the glaze is missing from the bottom/outside of the pan outlet where the flexible connector attaches the pan to the soil pipe. Is this a problem / likely to cause leaks? I would have assumed the surface area should be glazed / smooth all the way around to ensure a water-tight seal. Took the pan back to replace at B&Q but all of the others were the same and the refunds dept said it was probably a manufacturing fault and I'd probably have to upgrade. Problem is the only other traditional style they have is £180!
Any advice much appreciated.
