View the thread, titled "Gledhill Torrent Immersion - Stuck element" which is posted in UK Plumbers Forums on UK Plumbers Forums.
T
Taggartis
ive got an issue with an emersion heater whereas the element needs replacing. ive had a plumber in to remove it but it wont budge even with heat added. ive called another plumber and mentioned this but they all seem to think forcing it may buckle the tank. after googling the issue i read a post here involving cutting out the element.
Anyone good at getting these things out? Or cut one out before?
its a gledhill torrent boiler and im dreading the though of needing a replacement. Im in sunderland.
if anyone can offer any assisantance or advice id be very grateful.
Cheers
if its stuck solid then wacking it out can destroy the cyl, however make sure your plumber gives it a go with the cyl still full to absorb the beating. if all else fails stitch out the immersion with a drill and you may get lucky, but all the time spent trying may be better spent on a new cyl in the short term.
gledhill torrents arent cheap.
there are cheaper alternatives. speak to your plumber.
p.s i havent come across an element yet that i couldnt get out with heat and a pair of 24inch stillsons. that said there is still a risk of damaging the cylinder
p.s where abouts are you based? perhaps one of our members is local to you.
Reply to the thread, titled "Gledhill Torrent Immersion - Stuck element" which is posted in UK Plumbers Forums on Plumbers Forums.
