E
ed1971
hi i hope someone can give some advice. The trouble i am having with my glow-worm 24cxi combi boiler is as follows. Even if the central heating is off via the thermostat if i have the hot water switched on its starts the central heating as well and so the hot water barely gets hot in the bathroom. i had some plumbers in and they thought it was the diverter valve so they replaced that with a new one and im still getting the same problem. so they have charged me for that and told me to go to glow-worm direct. Before i do and spend even more money i wondered if anybody has come accross the same problem. Many thanks Loyd
I would be Asking the plumbers to return.
You cannot interfear internally with the boiler as your not qualified.
Turn off the flow under the boiler (instructions will be in your user instruction book)
Run hot tap.... If DHW performance is much better then you have shown that the diverter isn't working properly and the nuggets need to come back.
Don't you dare open the boiler case !
sorry for the late thank you, i have turned the heating flow off and i get good hot water. couple of things even then, it still tries to turn the heating on every 20- 30mins does this still point to diverter valve. can i keep the heating flow turned off for long periods?
Good advice given (Thanks Ermi)
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
