N
ncossa
Hi, my glow worm boiler has just come up with the F5 message which is apparently due to over heating. A plumber has said that it's the pump not working, he says the pump seems to be fine but there is no current going to it from the pcb so apparently I need a new pcb. Is this right? Just want a second opinion as the cost of pcb's are high!
the same happened last year and a different plumber changed a valve (don't know which) and reset it and that solved the problem.
Am I going to have something happen every year? I've only had it 6 years.
thanks.
thanks.
