View the thread, titled "glow worm 30si combination boiler flashing F2" which is posted in Boiler Advice Forum on UK Plumbers Forums.
K
karenhus
Can anyone tell me what F2 means on a glow worm 30si combi boiler. For the last few weeks I have had to adjust bar pressure but today I have switched the boiler on and nothing has happened. I cant even the see the flame so presume that it isnt even lit.😡
I'm pretty sure that F2 refers to an air problem ie. Air pressure switch or fan. Time to get a RGI in.
Steve
'02' and 'F' and 'flashing red led' Air fault, pressure switch, no power to fan
plumber not coming until monday. Flashing F2 not F 02. Does this make a difference.
Plumber came and replaced fan and PCB but still not working. Help!!
also checked air pressure switch and its fine
...but did he check the tubes to the pressure switch? I have found earwigs clogging these things before now? Also they can often perish and have small cracks in them which will make them work intermittently. If your RGI has only done half the job then call him back!
Reply to the thread, titled "glow worm 30si combination boiler flashing F2" which is posted in Boiler Advice Forum on Electricians Forums.
