View the thread, titled "Glow worm Betacom 24c" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
andyreno205
Hi
I've just installed a Glow worm betacom 24c, and everything is working as it should, heating and hot water. The problem that I have encountered is that the timer clock doesn't seem to be working. I know how to use one as my previous Radiant had one. So obviously the problem I have is I can't set the heating to come on or turn off in Auto mode.
I have checked that all the connections are connected securley and they all seem to be fine. Any ideas anyone???
Cheers
andyreno205
The clock has probably had it. Try another one you know is working, then you can eliminate any problems with the boiler.
Reply to the thread, titled "Glow worm Betacom 24c" which is posted in UK Plumbers Forums on Plumbers Forums.
