View the thread, titled "Glow Worm Compact 100E" which is posted in UK Plumbers Forums on UK Plumbers Forums.
fubar1000
Afternoon all
I fitted a gas valve in the above over a week ago & now the boiler is doing the same thing again
Boiler would light for around 3 sec then go out, this would continue until the boiler was manual shut down.
Fitted the new gas valve, tested & the boiler run like a dream.
Now the custard has just phoned to say the boiler runs for 3 sec then goes out
A/P/S seems ok, fan seems ok, no other issues with the boiler
Any ideas please people????
Check to see if dhw light is slightly lit, if so the gland on the dhw valve is leaking onto & shorting the micro switch & causing the boiler to fire up. Can also cause it to overheat or just fire up for short intervals, thinking it's diong dhw.
aggis is the winner lol
The dhw light advice was spot on
How on earth would I'd find that without the little nod from aggis I don't no
Big thanks for that mate
Merry chrimbo people
That's one for the little black book
I had one where another engineer had fitted gas valve and not set min burner pressure so when it modulated down it went out . worked fine on hw and heating until temp reached .pcb poor on these boilers
Reply to the thread, titled "Glow Worm Compact 100E" which is posted in UK Plumbers Forums on Plumbers Forums.
