SMP1
I'm a fairly proficient DIYer and was fitting a ADEY Magnatec to my daughters central heating system, connecting it to the return flow beneath the boiler (recommended as the ideal position in the instructions).
In order to install I needed to slightly modify the pipework to allow sufficient space, so disconnected the return flow pipe from the boiler "water service stopcock" (as described in the parts list found online). I also disconnected the "water service stopcock" from the boilers "pressure relief connector" which is a plastic pipe, so I could clean it up as it was a bit mucky and possibly weeping very slightly, however I'm now struggling to reconnect this to achieve a watertight fit.
Looking at the parts in the online schematic, it show that there is just the nut and a washer to join the two together, I thought maybe I'd dropped and lost a bit. Unlike a compression fitting where the olive helps obtain a nice tight fit, I don't quite see how the nut and washer achieve the same, as there is only a very very minor lip on the end of the pipe, which you can just feel with a finger nail. The "water service stopcock" is held in place by a spring clip against the casing framework but then tightening the nut, with the washer inserted, is very difficult to slide onto the plastic pipe due to very limited space. I've connected it a few times and it fails to achieve a tight fit.
Has anyone any experience of fitting these and know what I might be doing wrong. The washer is slightly compressed after use but not actually damaged. I've also found all parts available online as spares, but am not sure whether I would still have the same issues with new parts.
I've attached some photo's, showing the water service stopcock, nut and washer. The area beneath the boiler where it fits and another pic showing the same connection for the central heating outflow. I've also shown an image from the schematic and the spare part image for the pressure relief connector.
Any advice would be much appreciated, it seems such a silly issue to have?
Regards
Steve
Regards
Steve
