View the thread, titled "Glow Worm EP50B burner cuts out prematurely" which is posted in UK Plumbers Forums on UK Plumbers Forums.
H
highongas
Hello Ladies and Gents.
New on here, but have seen many posts from various members, and everybody seems helpful.
So, please can somebody express an opinion on this problem.
Good pilot light with new thermocouple.
New boiler stat
New room stat
New overheat cut-off
Recent 3 way valve
New pump
Boiler will run for several minutes, but then cuts out as if the room stat is satisfied, despite being several degrees below stat setting. Water flow is excellent, as the furthest radiator heats up almost as quickly as the closest.
Could the gas valve be faulty/weak?? What else that has not been replaced can cut the burner gas supply?
Any helpful comments appreciated.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Glow Worm EP50B burner cuts out prematurely" which is posted in UK Plumbers Forums on Plumbers Forums.
