View the thread, titled "Glow.worm Hideaway 115C FF" which is posted in UK Plumbers Forums on UK Plumbers Forums.
E
ed209
bit of a long shot but if anyone comes across the above boiler Being replaced I need a cap for the vertical flue test point, it is not threaded , has been capped for approx 10 years with 22mm speedfit stop cap.
Or other suggestions, I can actually get a brass compression 22mm stop end with the olive to fit very well
But not manufacture approved fitting and customer worries it will be "at risked " by BG
again, as they are the ones that AR it recently.
Part discontinued by GW
boiler is in perfect condition apart from that BG obviously want to fit him a new one.
I would accept a compression cap end if I came across it (as long as it fitted all the way and the olive fitted)
Reply to the thread, titled "Glow.worm Hideaway 115C FF" which is posted in UK Plumbers Forums on Plumbers Forums.
