View the thread, titled "Glow worm space saver MKII problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
Applejack
Hi
I have a glow worm space saver MKII boiler. It wasn't firing up and thought it was the main boiler thermostat & thermocouple, I purchased a new Ranco CL6P0102 boiler thermostat c/w thermocouple fitted it and the boiler fired up. This worked for a couple of days then the same thing happened again. If I turned the boiler thermostat to the off position, then turned it back until it was just on, it fired up, however, if I moved it to a higher temp it cut out. I refitted the old unit and all worked OK, I then refitted the new Ranco unit and this worked correctly. is there something else that can cause this type of fault?
Many thanks David
We will not give information relating to DIY gas work. It is illegal and against the rules of the forum
Reply to the thread, titled "Glow worm space saver MKII problem" which is posted in UK Plumbers Forums on Plumbers Forums.
