View the thread, titled "Glow Worm ultracom 38cxi heating" which is posted in UK Plumbers Forums on UK Plumbers Forums.
shedman
Hello, got possible problems with my 38cxi when in heating mode, once the boiler heats to the boiler s.p, once it exceeds the s.p by 2 degrees it resets and circulates for 5 or 6 minutes and the radiators cool to luke warm then it will ignite again and heat the radiators then the same thing again.
This is the first combi I have had , is this how it should operate 🙄
any advice would be appreciated.
regards,
shedman.
Most modern boilers have a built in time delay between reaching temp and re light of burner to avoid cycling and increase efficencey
puddle thanks for the reply, I am finding that when the boiler fires up the forward temperature heats up very quickly (20- 30 seconds) two degree over s.p goes into anti cycling period, on checking the forward temp on d.40 and return on d.41 there is approx 12 degree difference, am I right to assume the anti cycling period is determine by setting on d.1 (water pump over run time for heating mode)which is set at 5 minutes, this could explain why the radiators are only luke warm when the boiler re ignites.🙄
regards,
shedman.
Reply to the thread, titled "Glow Worm ultracom 38cxi heating" which is posted in UK Plumbers Forums on Electricians Forums.
