J
JayDot
Hi guys, I have recently moved in my first flat with my partner and its the boiler situation isnt exactly great...
Firstly the boiler has only recently been fitted and was brand new so cant complain about that.
However our landlord has left us a servicing and fitting guide but no user manual, its not rocket science i know but i would like to understand why and how to fix whatevers wrong not just know that somethings not right.
Anyways on to the problem, info's a little sketchy as my partner was home at the time not me but here goes...
The gas man came to reset the meter as we have only just moved in, he couldnt do it as he had a problem with his card reader... He knocked on the door and said do you want everything turning back on now im done, my partner said if they were on before you came then yes..
Thats all the details i have but since he has been we have had no hot water and no central heating, the pressures on 1 bar and the first LED is green..
Could this just be something he hasnt put back on??
Regards, Jono
Re: GloWorm Betacom 24c help!? no hot water or central heating since gas man visited?
try resetting the boiler its in lock out,either turn the power off run a hot tap to create a demand turn power on or look at the instructions on how to reset
thanks mate ill try that, just downloading some instructions now
do you have any other gas appliances there ? to prove you have gas?
no mate, oven and hob both electric
am i right in assuming its not the pilot light as most new boilers will re-ignite themselves after gas has been turned off??
im going to go try it now, ill be back online if i cant get it going..
If not iv done it, thanks for your help gasman much appreciated 🙂
Tries resetting boiler last night and no use... The fan kicks in when you run a tap and there's a secondary 'woosh' as if something was igniting inside but no hot water or heating
May be a one you've already checked JayDot but if you go to your card meter does it have 'ON' on the screen? Push the red button and the screen should spring into life. Also check that the meter tap handle is vertical 'ON'! If you know you're gas is on then try several re-sets of the boiler. If it still isn't lighting let your landlord know as it's their responsibility to supply you with heating and hot water! :smile5:
Thanks diamondgas, when you push the red button it says 'M' and the tap is on
