DIYSB
Had a problem for a couple of months now and tried everything I can think of without success. I've been told the symptoms are know as Boiler Lock-out.
I have a Gloworm15hxi boiler and the problem is that it works fine when there is a demand for CH and HW or just CH but when there is just a demand for HW it shuts down very quickly. I have replaced the pump as part of maintenance programme and have now also replaced the Honeywell Y Plan diverter valve and powerhead unit. Upon inspection of the old valve it appaeared to be in good order and was working properly. I also replaced the themostat on the hot water tank just in case that was the problem but still the problem persists. There is a by-pass valve around the 3 port valve and that hasn't been touched and is fully open.
The problem only materialised after the summer when the demand for CH began. Before theat it had been working fine with just HW being supplied by the boiler. I've had it serviced and its working ok. I'm not a plumber or gas fitter but do most of my own plumbing jobs (leaks,taps, radiators etc) but would never go anywhere near gas.
So I'm scratching my head as to what could be causing it and was hoping someone here might be able to give me some suggestion?
