View the thread, titled "Glowworm 45/60" which is posted in UK Plumbers Forums on UK Plumbers Forums.
What are you after the M.Is for this is a very old floor standing boiler with not a lot of tecnical bits on it?
Well my main reason was the flue setup but I realise that info won't be in the manual. Will be good to know the minimum clearances and ventilation requirements though...
Not sure about clearances. They came as range rated 45,000 to 60,000 output not input in gross so should be able to work out ventilation using the higher figure in the normal way.
Ventilation is via your kw and dependent on vent route etc and the flue distances have been roughly the same for all boilers for years. what bits do ya need to know ?
Cheers lads. I meant clearances around from cupboards etc. just wanted to go armed with as much info as poss tomo.
Good luck just a basic old open flued boiler with no special requirements
Reply to the thread, titled "Glowworm 45/60" which is posted in UK Plumbers Forums on Plumbers Forums.
