View the thread, titled "Glowworm cx30 flexicom prv or expansion vessel fault" which is posted in Central Heating Forum on UK Plumbers Forums.
Hi, my boiler was consistently dripping from the expansion vessel with the pressure at about 2 bars or higher with fault f1. I was told to bleed a radiator and pump air into the expansion vessel , so I did up to about 4 psi. Suddenly something gave and water gushed out of the safety pipe outside the house. When I kept pumping, eventually air and water started fizzing out of the expansion vessel. I reassemble d the boiler, filled the filling loop, and repressurised to c. 1.8 bar. All seemed to work, then pressure fell quickly. I looked outside and it is pouring from the prv. Now faults show f9 and f22. System can't hold pressure, no heating, no hot water except when I keep filling it up. Any ideas? Is it prv I damaged when pumping or expansion vessel or both?! Thanks!
Reply to the thread, titled "Glowworm cx30 flexicom prv or expansion vessel fault" which is posted in Central Heating Forum on Electricians Forums.
