View the thread, titled "good price for a kit?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
No I wouldn't bother myself.
I doubt id bother with the blow torch. Definitely not the immersion spanner, better with a boxed one.
Not used the basin wrench for a long time. Although might be handy.
Pipe slices are worth £25. Can't see the bag. Adjustable spanners are about £4-£6 at my local tool shop.
Id buy what you need seperately
What in that kit do you need? I bet you could jig the list around and get better quality stuff.
Box immersion spanner all the way, you struggle to get stilsons on that one!!
Blow lamp?? good for a bit of 15mm??
Always good to have some cheap screw drivers/ chisel's around!!
A tape is a tape is a tape!!
Adjustable's, I really like my Bacho's, Wide jaw 8" the 10"/ 8" and 6" wouldn't use the ones from the market stall, although good for stater!
Head light, available from every where!
Haven't seen my Shetack for a while!!
other than that!! OK!!
My advise for what its worth!!
Buy the best you can afford now, get used to using all the tools that we need, then buy as you can the tools you want! I've been doing it for over 10 years and still looking at new "toys" as the wife says!!
Bacho spinners are the mutts nuts, I would defiantly recommend them.
Think I've had my wide jaws for over 8 years, a bit of WD now and again like new!! managed to get the other set at a trade show at a show price, other wise don't think I would have got the whole set!!
They do cost some, very rarely on a special anywhere but I rate them as some of the best.
In the grand scheme of things there actually not the bad 8 years use for(can't remember but) £30+ pops into my heads, may have been £39.99. but I recon I chucked at least 2 pairs from the market before I man'd up and got some Barcho's!!
wouldn't go back now!
Good money for a load of tat.
Disagree about tape measures, there are good ones, and bad ones.
As for spanners, I recently bought a load of spanners in the right sizes and they're LOADS better than adjustables.
Full set of ratchet spanners from 8-19mm for boilers etc.
16mm spanner for rad tails, 24 and 32 for comp nuts.
This thing is the best £6 I've spent in a long time http://www.amazon.co.uk/gp/aw/d/B001VD5CA8
The Forge Steel pipe slices from screwfix are pretty cheap at £18 and very good. Had 2 sets now and they're IDENTICAL to the bahco slices which cost a fortune.
As an Amazon Associate we earn from qualifying purchases.
That six quid you spent tom, I spent three on same thing from toolstation. Very handy. Trouble is I keeo forgetting I have it...
The toolstation ones aren't as good though.
I've had both and the six quid one is better, longer and heavier - heavy is good, heavy is reliable.
Reply to the thread, titled "good price for a kit?" which is posted in UK Plumbers Forums on Plumbers Forums.
