G
Gixxerman
I have had some quotes for a boiler replacement.
I wanted a Worcester Bosch 12Ri, a full power flush, magnaclean and rad valves.
In the end I decided to go with British Gas as you know the job will be done right (not that independant plumbers won't do it right, but you know what you are going to get from BG).
Anyway this is the quote:-
Replace Apollo 15/30b with Worcester Bosch 12Ri.
2 years HomeCare 200 free of charge.
Flue.
Brick work.
Water treatment and powerflush.
Magnaclean professional.
Chrome rad valves throughout.
Wireless room thermostat.
Inside routed condesate pipe.
This includes the fitting of new 22mm gas supply pipework (if required - they will try it with existing 15mm to see if it works to save hassle), lifting of floorboards to fit pump run-on connection.
Total price £3200 which reduces to £2800 when I get £400 back from Mr Brown from the boiler scrappage scheme.
Is this is competative price?
I reliase BG are are going to be more expensive than everyone else.
Flue.
Brick work.
