View the thread, titled "Grant oil boiler required" which is posted in Boiler Advice Forum on UK Plumbers Forums.
N
nccoogan
Hello, I need a Grant Multipass 70-90 Kitchen model oil fired boiler. They are no longer made so I am after a second hand one. I need it to test a burner unit that I already have so the burner is not required, just the other parts. Age or condition is not important, as long as I can fit my burner to it and fire it up. If anyone has one or happens to replace one if these I'd be interested in buying it from you. Thanks
I was told by grant that you could still buy their standard efficiency boilers but you will have to order it and it will be made specially for you,it takes about 6 weeks Commercial propertys dont need to have condensing boilers fitted which is why they still make standard eficiency ones.
Just bench fire it. Or more to the point garage floor. Admit it's not ideal but it's easier than sourcing a second hand boiler just to test your burner.
Reply to the thread, titled "Grant oil boiler required" which is posted in Boiler Advice Forum on Plumbers Forums.
