A
algea100
Hi have grant Vortex 26 Combi no hot water, have renewed dhw circulating pump and dhw pcb and sensor don't seem to have flow through heat exchanger any ideas?
Thanks great help!!!!!!!!!!Expensive when you don't know what you are doing. Get a decent engineer out.
No, Are You?!!!Not gas safe are you?
No, Are You?!!!
No, Are You?!!!
You're correct rpm it is oil but all the same I've lost interest in the op as he's clearly not qualified to work on it
prehaps a more sympathetic approach is called for, and advise to use local oftec techie, who may be found on here. After all going on about being gas safe is a bit of a waste of time! reading the manual is a good starter for 10 and is what a techie normally does to find the first place to look. http://www.grantuk.com/wp-content/u...rvicing-instructions-DOC88-Rev00-May-2012.pdf then use someone who is good at fault finding and get them to service it once it is running again
Who are you and why are you on Lames account?
Reply to the thread, titled "Grant Vortex 26 Combi No hot water" which is posted in Bathroom Advice on Plumbers Forums.
