View the thread, titled "Gravity fed shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
mjt
Hi
live just replaced a gravity fed bar shower mixer which seemed to be working fine when I left it.
Customer has called back saying when the shower is raised to the height of the bracket the temperature dros to a Luke warm temp.
When it comes down to waist level it's fine. I think it's a pressure or lack of issue but not sure what you chaps think
Have a good weekend
MJT
Lack of pressure due to insufficient head on the supply. You need to either raise the cold feed tank or pop a pump on it.
If it is ok at waist level you will probably need to raise the tank by around a metre.
Reply to the thread, titled "Gravity fed shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
