the cylinder must be suitable for gravity/solid fuel systems
primary pipework to be a min diameter of 28mm
primary circuit as short as possible
cylinder to have a min of 1m and max of 6m head
pipework to keep rising inclined as steep as possible
fit a self setting temp pressure relief valve on the cylinder
heat leak rad/s with 22mm pipework
open vent to be a min of 19mm ID
feed to be a min of 13mm ID
controls to meet part L of the building regs
float to be copper
overflow to be copper
most of this is from hetas.
theres a way of figuring out the actual pipe sizing, but you need to know the correct temps and distances to work out the force of the water, and frictional restrictions of the pipework and cylinder. Somebody brighter than me may be able to guide you better on this tho
above all you must follow the stoves and the cylinders manufacturers instructions.
http://www.solidfuel.co.uk/pdfs/link_up.pdf
