View the thread, titled "gravity hot water on a single system" which is posted in Bathroom Advice on UK Plumbers Forums.
A
aladin
hi all
i was called to sort out a no hot water problem gravity fed pumped c/h some one (not me) fitted a new pump now no hot water i suspected a air lock tried to clear but no, any ideas been too long on gas not plumbing any more cheers
Check the pump speed. If set too high it can stop the gravity circuit if it has a low circulation head.
Other than that, check the system is full or airlocks at the coil.
Reply to the thread, titled "gravity hot water on a single system" which is posted in Bathroom Advice on Plumbers Forums.
