View the thread, titled "Green star 24i fan running constantly" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Millsy 82
I've got a fault with above and I have a nagging suspicion that it is a fan fault although everything is pointing towards pcb.
Have I just imagined this is the problem with the fans?
Could be PCB,
Have you check wiring harness ( control wires), from PCB to fan ? For continuity.
Quick call to Worcester technical I reckon, they soon be able to help, expensive mistake if your wrong lol!
Too true !
Always best to get a second opinion from them !
Even if you're convinced your right. Once you buy the board, it's yours as you no doubt know.
I phoned them twice and got 2 different answers. They have really gone down hill on there customer service I think.
I've had the same experience. It's hard work sometimes and pot luck who you get. One day it can be a field engineer who is experienced and knows the job and the next can be just the opposite.
Try checking the live neutral for 220v first and then the other wires for DC voltage , I think you should get around 5v on these . If you can disconnect the low voltage wires and fan still runs then it's a faulty fan . Hope this helps.
Reply to the thread, titled "Green star 24i fan running constantly" which is posted in UK Plumbers Forums on Plumbers Forums.
