R
redcuckoo
I would be grateful if anyone could give me some advice on a problem i have with a Worcester Greenstar 28i boiler that is fine when i turn the hot tap on but is not firing up to heat the rads. I have pressed the reset button on which the boiler fires up for a few seconds then cuts out. I have been able to put it into service mode & the rads will then heat up.
I have 1 room thermostat located in the hallway & ive noticed that when i turn the dial there is no clicking noise at all. Could this be the source of the problem???
Thank you in advance!!!
