E
emerald
in my travels i have come across a few condensing combi's mounted on plywood, and gas safe havnt given me a definitive answer on weather this is AR or NCS what do you guys think?
ive been after you and your 105he instants emerald, and had to take em off to install the old aspestolux lining. only joking of course but round here it seems a common practice to disregard the need to have a fire resistant surface to mount the boiler on. But as we are both aware, some of the hotels round here burn really well and at regular intervals, i reckon the Berkley is the next for the tourist entertainment evening this summer, if the colli hasnt burst into flames first. if only the boilers had been mounted properly!!!!!!!!!
Or it is actually on fire, which is an immediate danger.It would be N.C.S and if signs of scorching would elevate to A.R.
Would only be I.D. if there were indications of severe scorching that may combust.
If boiler is mounted and ply and there's scorching marks then its I'd. If no scorching marks then its ncs
Hmm!
There is something about mounting boilers on fireproof boards somewhere!!
It would be really great to be able to go to one website and download a definitive answer to all those grey areas you come up against.
Working as a contractor for a large Housing Association its amazing how many grey areas you do come up against. And the fighting about them can tire you out at times.
Don't forget a landlord will not usually pay for something he does not have too and any expenditure has to be proven to be necessary. In practise you have to get all the books out and state which reg requires you to do the work and so on. The landlord will usually also get his copy out and check what you say.
The problem is, in the grey areas there is often no one answer. And not only current regs are involved, so you can have a hard time trying to sort it out.
In general though I suppose a lot of gas work can have answers if they always bias toward safety.
For instance, making FFD devices compulsory on all gas fires regardless of how old or what regs they where fitted under?
Imagine the fighting over that though?
Reply to the thread, titled "Grey area" which is posted in UK Plumbers Forums on Plumbers Forums.
