GROHE smart control tap
View the thread, titled "GROHE smart control tap" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi just purchased above tap it has 19mm flexi tails and want to fit to a standard 15mm isolation valve.
Is there an adapter available as isolation valve is male type, so 19mm flexi needs to screw onto standard 15mm coupling.
Any advice appreciated.
I don't know what screw caps are.
The spec says G3/8" and I've done enough Grohe stuff to know thats what they normally are.
Is your pipe work 22mm?
yes 22mm so your right its just a 22mm male connector to 10mm flex adapter just found 1 on screwfix. I will use the screw nuts from a couple of straight connectors I have spare to connect the small piece of copper pipe to 22mm male connector cheers
I think OP is talking about measurements in mm across the fitting - which we all know has nothing to do with what they are called in bsp or G as they get referred to nowadays.
I think you’re both talking about the same thing.
Reply to the thread, titled "GROHE smart control tap" which is posted in UK Plumbers Forums on Plumbers Forums.
jrmroxx,
jrmroxx,
