Guest viewing limit reached
Grundfos Alpha2 15-60 130
View the thread, titled "Grundfos Alpha2 15-60 130" which is posted in UK Plumbers Forums on UK Plumbers Forums.
The above pump is showing all of it's lights on screen and is flickering without the pump actually working. The boiler also seems to not be firing up as it should making a lot of noise when it does try to (or at least the pipes above it do).
Is this a pump issue or a boiler one?
Thanks for any advice.
It's just a blue light in the middle which is on. When I try to reset it it used to make a kind of clunky noise to let you know it had reset but it doesn't seem to be making that noise anymore.
Yes, it's calling for heat and water. It comes on now and again when calling for hot water but more often than not it doesn't now. The light isn't flashing it's just constantly on.
I just tried turning everything off and then:
1. Calling for heat only - the pump lights just flicker and the pump doesn't come on; the boiler makes a noise but doesn't start up properly.
2. Calling for water only - the pump lights just flicker and the pump doesn't come on; the boiler doesn't even make a noise.
Yes, those are all fine.
I think the pump needs replacing....
Just wondering how you got on with this issue as I have the exact same problem with mine! C/H and H/W stopped working yesterday and on inspection I found the front panel of the GRUNDFOS ALPHA2L pump to be flickering and unresponsive. I'm going to try and power it from an alternative source after work tonight but if I get the same result I assume my only option will be to replace.
One question I have is am I right in thinking I can detach the pump body using the 4 allen key bolts and leave the back bit connected to the pipes? Seems that would be a lot easier than full replacement?
Reply to the thread, titled "Grundfos Alpha2 15-60 130" which is posted in UK Plumbers Forums on Plumbers Forums.
Vik123,
RainbowClark,
