Phillay
Hi chaps,
Having to install acondensate pump below my new boiler and I'm a bit unsure of how towire this in. Boiler is a Worcester Bosch 28kW Compact and I have aHoneywell CM900 RF stat wired into the set up for heating control.
Purchased a GrundfosConlift1 to pump away the condensate. There's the twin core &earth power supply cable and a two core safety overflow switch cable(0.5mm).
The boiler is currentlypowered by a 3amp protected double pole FCU and 0.75mm heat resistantflex cable.
The receiver for the RFstat requires a link from 'L' to terminal 'A' ('B' then wires to 'LR'on the boiler). I believe I'm right in thinking I can remove thislink and replace this with the safety overflow switch cable from thepump. Brown (COM1) to 'L' and Blue (NO4) to 'A'. This will then actas the link, and break it should the pump fail, stopping the heatingdemand.
Regards the pump powersupply, is it acceptable to wire the power cable into the same 3ampFCU as the boiler? ...The manual does state “check that theinstallation has a 10amp slow blowing fuse on the mains side”.
Cheers for anyinput/advice
P.S. Sales literatureindicates the pump runs at 0.65amps.
