Guest viewing limit reached
Grundfos Pump - has it failed?
View the thread, titled "Grundfos Pump - has it failed?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Snowsride
My Boulter Buderus Camray boiler has shutdown and I think it may be a failed pump. It has a Grundfos UPS 25-60 pump fitted and I removed the large screw to check if the impeller was rotating. From past experience I would expect a steady, but not powerful, stream of water to run from the bottom of the screw hole but I am getting a thin, powerful, jet of water coming straight out of the middle of pump shaft - it almost looks like there's a hole or depression in the middle of the shaft - there is no keyway so I can't use a screwdriver to try to free it up.
When there is power to the boiler it sounds like the pump is running but as soon as the boiler is actually switched on it locks out.
Grateful for any advice.
If you put a large flat head screwdriver you will be able to turn the shaft. Have you checked water press in the system?
Sent from my iPhone using Tapatalk
Reply to the thread, titled "Grundfos Pump - has it failed?" which is posted in UK Plumbers Forums on Plumbers Forums.
Snowsride,
Snowsride,
