Guest viewing is limited
grundfos pump switch
View the thread, titled "grundfos pump switch" which is posted in UK Plumbers Forums on UK Plumbers Forums.
solohound
is it possible to change the electric switch and speed control on a grundfos pump and if so how to do it
it is a grudfos tf110 and the three way switch will not turn the pump on the pump turns manually ok
Unlikely the speed selector has failed. Much more likely the windings have failed. You're looking at a new pump.
You might be lucky. A merchants may still have these on the shelves but it's more likely you're going to be fitting a smart pump.
More expensive initially but it'll save you money in the long run.
pump works if you put pressure on the switch ie push the white slotted switch with a screwdriver
Reply to the thread, titled "grundfos pump switch" which is posted in UK Plumbers Forums on Plumbers Forums.
solohound,
solohound,
