View the thread, titled "GulfStream SS30 Help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
russ9898
Hi guys,
My parents have a Gulfstream SS30 installed in their house and recently it appears that the top and middle floor of the house have no/little heating.
I'm lead to beleive that the property has 2 heating zones, one for the ground floor which ill call zone 1 and one for the upper and middle floors which ill call zone 2.
Zone 1 appears to be working fine with the radiators getting red hot and the place generally being kept at a comfortable temperature.
Zone 2 however is another story. The place is freezing all the time, most the rad's are stone cold and the odd couple are look warm at best. Ive bled the rads and none had any air in with water flowing straight away from them. This unfortunately is about as deep as my plumbing knowledge goes.
The hot water is working fine and a constant stream of hot water is always available.
Electrically it all seems to check out (im a qualified electrician btw) The room stats on both floors are getting 230v as required. As i said zone 1 is working spot on so i have swapped the room stat from zone 1 with zone 2 to eliminate the possibility of a faulty stat. I'm now completely lost and was wondering if anyone could help me at all?
The stats installed in the property are Honeywell CM67's.
Thanks in advance for any help provided and if ive left out any information which may help you diagnose the fault then please shout up.
Thanks again,
Russ
Just been playing...
When i call for heating on zone 1 the level on the 3way diverter valve moved from one end to the other. It doesnt however seem to drop back out again until i turn the boiler on and off
If i call for heating on zone 2 then the level on the valve never moves even after a few minutes of waiting.
Reply to the thread, titled "GulfStream SS30 Help" which is posted in UK Plumbers Forums on Plumbers Forums.
