View the thread, titled "hair salon hot water?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
sinkyb
Hi there, my wife is going to be opening a new hair salon and i am looking for advice on which is the best way to heat hot water for the 2 backwash units, there will have to be good pressure at the units, the shop has a gas supply and a combi boiler fitted at the moment was looking at the rinnai 16i to heat water but open to help and suggestions
I fitted in my friends hair dressers , a system boiler ( 2rads ) 150 lt unvented , plenty off hot water , plus boiler not working can always put immersion on , they use to have a Andrews water heater , it was a beast
Did one recently it had awful incoming and was a 5year lease. 2no 120l open vent cylinders on separate s plan two coffins and pump sets .
thanks for the replies guys, what actually is the most cost effective way of heating water? gas or electric? sorry i have not got a clue on this subject!
Gas.
rinnai water heaters are good
what are you looking to do with it in the future?
any expansion?
something to consider is that rinnai unit + the combi boiler will likely be over your gas meters capacity (depending on what it is already there) so an upgrade would be needed.
likely a better solution would be an unvented cylinder run by the combi boiler
are you open to forum members doing the work?
we are a pretty good bunch 😀
If they need lots if hot water and leccy for the dryers etc you could think laterally and consider a Baxi CHP unit ....
You size the boiler and storage cylinder so the boiler is running for as long as possible, - cylinder sized to provide a buffer in the demand cycle. (They paid to generate the leccy AND save on the leccy bill 🙂 )
It depends on the temperature of water required and the flow rate required.
We use a lot of Rinnai's over here, but as the temperature of the water required goes up, the flow rate out of the appliance drops...significantly.
Really more info is needed.
They only had. 4! But were rammed. 12 staff .
Only 2 basins better go with the Rihanna then.
ah right! With all these suggestions he'd have a bigger gas meter with cracking plant but then no room in the place to get customers in!
Great performance from the taps though!
Reply to the thread, titled "hair salon hot water?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
