View the thread, titled "hairdressers hot water" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
W
WOLDEN
i,m taking out a andrews 190lt open flue unvented cylinder , not sure what advice to give for hot water supply . has to feed 4 basins .
has to be gas , not keen on direct heating..
unvented cyl and heat only condensing boiler if the customer wants gas, local hairdresser i work for happy with Mira showers over basin and shared combi for sinks and wc basin, cheaper to put in 4 miras than cyl and boiler imho
and cheaper to replace from a maintenance point of veiw😀
inresponse to "wot about a combi?"
have you run 4 showers off a combi? a busy hairdressing salon will do so, you need stored water or 4 independant heating units
Have one,works off a normal cylinder ,storage tank above,with pumped supply to outlets or could use a couple of multi points if main ok
or multi point and electric heaters for each shower
I have replaced Andrews open flued unvented cylinders with Ecocents before, a straight forward change and you have no need to reconnect the gas.
Hi. This is simular to which unguided mentioned [DLMURL="http://www.andrewswaterheaters.co.uk/products_details.php?product=ECOflo"]ECOflo Range EC[/DLMURL]
Reply to the thread, titled "hairdressers hot water" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
