View the thread, titled "Halstead Ace High Boiler firing up then turning off" which is posted in Boiler Advice Forum on UK Plumbers Forums.
N
Nsr500rossi
Hi, just visited my mum who lives 120 m miles away, she has no hot water or ch
The boiler fires up ok (there are flames)
It then turns off after a couple of seconds, i here a click from the boiler.
the pressure gauge shows 0.
Any ideas as to what this could be
Many thanks
Mike
Really, that easy, why would the pressure have dropped?
I can fix cars, bike and computers...but this boiler lark is all new
M
yep, most cases, but if loosing water ie. once a month then would suspect awater leak, from a joint mybe on or near a rad, is allways agood place to start, let us know how you get on😀
Hi
Well my dad has had a go at fixing the boiler but is having no luck
I will relay the info he has given me
He has bled the radiators and the the pressure down fill.
He said there was a leak from then air vent valve at the top of the boiler, so he replaced the air valve, but it is still leaking water from the valve, or from somewhere near the top point of the boiler
When he tries it, the pressure rises to 1.5 bar then it leaks and the pressure drops
Any ideas why it would still leak, even though it is a new valve
Mike
I am not sure if it is the valve leaking or just from somewhere up high on the boiler, i think he was having trouble seeing where it was coming from
Would the leaking valve cause the problem..
thanks
well yes any leak will drop the water presure, but there must be a lot of water coming from it ,it would be pouring out,if its loosing presure so fast, so if i am asumming he cann"t see the leak or water from it , and they are no signs of water anywhere else, the only other place it can go is via the prv,check the discharge pipe, what part of the county is the boiler, they me be one of the lads on here that may what a( quick ) job. hope this helps a little chris...............
Hi Chris
thanks
me ma lives in Carterton in Oxfordshire
If anyone is up for helping (without charging insane money) then please reply
Mike
Reply to the thread, titled "Halstead Ace High Boiler firing up then turning off" which is posted in Boiler Advice Forum on Plumbers Forums.
