View the thread, titled "Halstead bentley 50 boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
W
walden
Hi All
we have just had a major problem with our boiler basically it would fire up when its called then about every 10 seconds its trying to re-ignite the burners and kept doing this until the boiler reached its temperature and this went on for a few days until one day the boiler just cut out, so waht we have done is changed the thermostat and PCB has of today but now when the boiler switches on it ignites the pilot but there appears to be no gas coming through to the burners for the pilot to light, we have turned the boiler off and on a couple times and still nothing,
Would the gas valve be at fault could it be that its closed shut, thus not allowing the gas through, the boiler is about 12yrs old
Regards Paul
Hi All
Found the problem it was the gas valve playing around once changed fired up lovely but during the evening we needed some hot water so i switched it over manually and the boiler completely cut out so i put it back manually back to central heating and still nothing so i switched the boiler off for a while and tried again still nothing i cant believe that by manually switching over would cut the boiler out even though this was working fine until the pcb and gas valve broke down would the pressure switch be broken down now that everything has been repalced? there is only one pressure switch on this boiler, the boiler itself is a fully pumped system with a 3 port motorised valve, i have also checked all the wiring within the boiler and the motorised valve circuit all seems to be okay, any suggestions
Best regards Paul
Reply to the thread, titled "Halstead bentley 50 boiler" which is posted in Boiler Advice Forum on Electricians Forums.
