A
andrewedmondson
My Halstead Finest Gold has no hot water.
Turning on the hot water tap does not fire up the boiler.
If the CH is on, turning on the hot water tap turns off the burner.
The microswitch is being activated by the diaphragm. There's around 5V across the microswitch.
Last year I cleaned out the heat exchanger because the HW was cycling hot and cold.
A new thermistor was needed a few years ago for a different problem.
I've run out of things to check. Any ideas?
