scotjan
Bathroom is downstairs
Cold water supply is straight from mains
Hot water is from tank
Header tank in loft
Expansion tank in loft
Heating system is vented gravity
Hot water is kept in cylinder in bedroom below the loft tanks
Hot water supply is very good pressure
Heating system has now been power flushed and is working normally – heating up rads much quicker
Hot water seems to be normal ie have hot water
· Previous installation which had no problems
Bathroom
Mixer tap for bath/shower
Two taps for sink
· Current installation
Mixer tap for bath – pressure for hot water and cold water very good
Thermostatic shower – not pumped- pressure is good. Although sometimes the shower runs for about 45 seconds and no water comes out. Then it’s ok
Mixer tap for sink- cold water pressure very good still. Strangely now the hot water trickles out , but I have been advised that the taps may be for mains pressure only.
· Problems now are
Water going into the big header tank in loft and over flowing consatntly.
Can be alleviated temporarily by running hot tap
Water filling up the tank even when the heating or hot water is not on.
Vent pipe above cylinder is full of water? Thought it should be for air vent?
Haven’t yet investigated where exactly the water is coming from to fill up the tank. Having said that when you run the hot tap you can hear the water refilling the tank. But when it is over flowing I can't hear any water running.
can hear water trickling in pipes around the cylinder and I never heard that before.
Contractor's suggestion is that it is due to low hot water pressure and the mixer tap is forcing the cold water back up to the hot water supply. That I need a combination boiler to address the low hot water pressure issue. But I didn’t have low hot water pressure before and still don’t except that one mixer tap.
An independent plumber suggested that I may have a leaking coil in the hot water cylinder and that I would need a new cylinder.
Or could it be an air lock?
Did have a massive air lock in central heating after work was completed but that is sorted now.
I'm so confused and don't know what to do
Header tank in loft
Bathroom
Two taps for sink
· Problems now are
