stewartacraig
Okay, I saw a couple of threads about this issue before, but I think my problem may be slightly different...
I have an open-vented hot water cylinder with a cold water feed and expansion tank in the loft which keeps overflowing whether the hot water/central heating is on or off. When I put my hand into the feed and expansion tank I can feel warm water is being forced back up the pipe which I assume is meant to feed cold water down into the hot water cylinder. The only way I can stop the overflow is by turning off the mains cold water supply to the house!
Things I have checked already...
Central heating is working fine. All radiators are full with no air in the system.
Thermostat on hot water cylinder works fine. When I adjust the temp down the hot water clicks off.
Ball Valve in the feed and expansion tank is working correctly. It's not leaking cold water into the tank.
Is it possible that the mains cold water fed into the system is forcing its way through a split coil in the hot water cylinder causing this to completely fill and force water back up into the feed and expansion tank? Or maybe there is some other explanation for this?
Any thoughts/ideas would be greatly appreciated.
Cheers,
Stew
Cheers,
Stew
