View the thread, titled "Heat exchange rate in cylinder" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Just a fast one for the experts
Does say heating water entering coil in hw cylinder heat the dhw faster if say the heating presure is say a bar and a half as oppose to f and e.
Also if hw cylinder was unvented would speed up heat transfer aswell??
Thanks in advance if i get a reply
That depends on setup in theory with both the same flow rate no as a copper cylinder can normally only do 5-7 kw
And unvented normally can do 20kw as the coil surface area is more
Reply to the thread, titled "Heat exchange rate in cylinder" which is posted in UK Plumbers Forums on Electricians Forums.
