Can anyone recommend a decent heat mat... my last one from the suppliers was literally paper thin, after soldering a joint you can literally poke your finger thru its brittle crumbly material =[ ... that was a waste of £8 quid, its always annoying having a burn on the wall also after using your new mat also !!!
Whats everyone else using? I got some Heat gel spray in the van, but i worry if it squirts on the fitting the solder wont flow...
