barronbathrooms
Have been asked to quote on a heat only boiler upgrade but been a while since I quoted for such work (been subbying), current system is semi-pumped (heating) with gravity hot water circ's. cylinder is not lagged and pump is really old as is programmer (Randal 102). Am I right in thinking to upgrade to part L compliant I will need to install new foamed cylinder, change to fully pumped and include a zone valve (3 or 2 port) new room thermostat and programmer and new energy efficient pump, customer has asked to keep old pump room stat and Randell programmer, I know the programmer can be used with a 2port valve but most new heat only boilers require a pump over-run so will it be compatible with this? Or can I use a wiring centre to add over-run?
Any advise much appreciated! Thanks
