View the thread, titled "heat only boiler ?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
R
royston
Got to quote for a replacement old glow worm wall mounted. Gravity circs to cylinder and pump on heating. They are not keen on a combi, dont want to spend much (as per usual ) and want to know if i can just replace like for like.
Now i dont think you can as im sure it needs upgrading to a s or y plan. Whats your thoughts on this one ? Cheers.
I'm sure you're right 'royston' ... There ain't an 'A' rated boiler that'll do gravity!!
gravity is dead theres no money in a system that will work with out fail for 20 years its all about thermistors and pcbs which generate money
She even asked me if i could use the old flue on the new boiler !!! Dont even think its worth quoting as every price is gonna be to much !
I think Viessmann do a four piper heat only, possibly the 100 iirc.
Using this four piper, you can use the existing gravity feeds to and from cylinder, and put an additional pump and 2 port on the what will be the new flow to the cylinder.
Reply to the thread, titled "heat only boiler ?" which is posted in Boiler Advice Forum on Plumbers Forums.
