View the thread, titled "Heat pump hot water cylinders" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
Has anyone fit the hot water cylinders with a little heat pump on the top that has ducts to bring inside and outside air in to the unit. Piping up wise is it just the same as a normal direct cylinder?
Reply to the thread, titled "Heat pump hot water cylinders" which is posted in UK Plumbers Forums on Electricians Forums.
