View the thread, titled "Heating Activating Water each time (Grasslin TowerC QE2)" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi - I have a Grasslin Towerchron QE2 programmer. When I set my own time for water, it will come on just as programmed...on it's own. But for the heating times, this also activates the water everytime. Even if I only Boost Heating, it will light up the water too. From the instruction manual, separate on and off times should be possible. Any ideas why the heating is activating the water each time, and how to stop this. Appreciate any advice. Thanks,
My initial thought would be like SimonG was getting at, is the programmer set for gravity HW and pumped CH in which case this will happen, however if fine before then unless someone has fiddled with the programmer then this won’t be it. The other option is a fault internally with the programmer.
Reply to the thread, titled "Heating Activating Water each time (Grasslin TowerC QE2)" which is posted in Bathroom Advice on Plumbers Forums.
