View the thread, titled "Heating design considerations" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I currently have a gas open-vented central heating system with radiators (10mm pipework) in a house built in 1988.
I'm thinking of having the boiler changed and swapping to a sealed system (to increase shower pressure).
Will this simply invovle a flush out of the system then changing the boiler and the tanks?
Would I be better sticking with the open-vented and installing pumps to increase the pressure for the two showers?
Installing a shower pump on your existing system would be your best bet. Not only is it a cheaper option but the pressure will be greatly increased.
Having a shower fed from a combi-boiler will not increase the pressure as it is mains fed and you cannot fit a pump to this system.
go for sealed system , and pumps for the showers. keep away from combi,s ...
system boiler with unvented cylinder provides the best results.
personally i'd have a broagg quinta with a flamco cylinder - better still a manco copper cylinder, from manchestercoppersmiths (pricy but the best and all made of copper)
Reply to the thread, titled "Heating design considerations" which is posted in UK Plumbers Forums on Electricians Forums.
