View the thread, titled "heating/hot water problem" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
dave1
🙂can n e 1 help please
i have a floor standing boiler in kitchen and indirect cylinder in airing cupboard, i can not have the hw and ch on separtly i have renewed the 3 port valve and pump neither has solved the problem not sure wether this is a problem with the wiring or not, if i put the prog on constant and the room stat on the heating does not come on hw seems to be fine and works off the timer well.
n e ideas please many thanks😕
Sounds like it could be a wiring problem or faulty stat. Time to get out the multimeter and wiring diagrams.
Mike
Upvote 0
Honeywell wiring plans are available on the web. Not only do they work, but following them will give you a working system and will also give you a fighting chance of understanding what is going on if you are called bck in three years time.
Upvote 0
Reply to the thread, titled "heating/hot water problem" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
