R
rockhopper
Dear All
I have a question relating to the use of fire valves in a oil fired system.
I currently have a worcester oil boiler and new oil feed coming nto the house which was commissioned 12 months ago.
I would like to install a oil stove centrally in my house. The feed from the stove will have to come from the nearby the boiler which is about 3 to 4m away. The boiler is protected by a fire valve....etc.
Do i need a new fire valve for the stove, the stove is close to the boiler and would the existing boiler fire valve be sufficent. If i do need a new one does the valve need to go outside or can it be located next to the existing boiler near where i will T off the boiler supply. For example a fire on the stove would result in the oil supply at the T closing, should a fire then spread to the boiler it own fire valve will come into working.
I am specifically asking as it is really going to be a pain in the butt to get a new fire valve from the new stove to the external pipes (dont want to have to rip up floors and plaster walls to hide the fire valve....etc.)
I have also seen some fire with the valves located very near the fire?
Any advice would be appreciated.
James
James
