I have a standard system boiler setup. I have a problem in that the hot water cylinder doesn't refill once it is emptied. eg. If my wife has a shower and empties the tank (it is only 120L and high flow shower), I then press the hot water button and the boiler does not fire up. If I turn on the heating only, or heating and hot water then the boiler turns on and fills the tank nicely, and the heating works. I wonder if there is some sort of sensor which tells the boiler that the hot water tank is empty and this isn't working?
Thanks.
Thanks.
