Y
Yellowpinky
Hi all,my system is sludged up and i`ve been quoted £1143 by BG for;
1 x Pump
2 x Valves
Drain/powerflush/bleed..
22mm magnetic something fitted to the boiler...
This seems really expensive as i can get the valves/pump for 150 and rent a powerflusher for 100 if i was a qualified plumber...
Can anyone please advise on this..
Also being xmas most plumbers are stacked out but i`ve found a guy who is free monday who said he could put in the valves/pump add something to the system to help it move a bit better and bleed...Then come back after xmas to powerflush....
Is this worth doing or am i just going to have new valves/pump with contaminated water running through them....
I`m still getting heat round the house but not more than 19 degrees...
I have a traditional system with an ideal boiler drayton za5 valves,not sure which pump and i`m running 11 rads...
1 x Pump
2 x Valves
